I am looking for a source for the engine parameters (oil press, fuel press etc) for the IO-540-C4B5 engine. I need this to set up the yellow/green/red zones of the engine indications.
Thanks.
Johan
Where is oil temp measured in the C4B5 engine. Before or after cooler? The data sheet that "jabarr" attached only mentions INLET oil temp. Not sure inlet to where.
Thanks.
Johan
Thanks.
Johan
Right in front of the oil filter. I highly recommend you download a copy of the Lycoming (I)O-540 operators manual, overhaul manual, and parts catalog as part of your library.
