Setting up gph k factor on -60 red cube
Phantom30
Okay, I have finally got gph flow thingy on my G3X. When I turn on master (aux fuel pump running), I'm showing 1 gph fuel flow (engine not running).
Obliviously, I need to adjust k factor to account for return to tank fuel flow. Current k factor is 68,000 (I think)...anybody got suggestions as to how much and what direction to fix?
Ric.
I got 107829 after a 1 hour cross country flight.
http://www.vansairforce.com/community/showpost.php?p=1069069&postcount=1
A more recent discussion here:-
http://www.vansairforce.com/community/showthread.php?t=152452
I recently asked Van's support about putting a second red cube onto the return line and got this reply:-
"I have no reasons to tell you not to install a second flow transducer. We opted to only use one as it proved accurate enough for our needs.
Sterling
Van's Aircraft
14401 Keil Rd
Aurora, Oregon 97002
503.678.6545"
I always start with empty wing tanks, then add a known quantity - 20-30 gallons or so. After burning that down to empty tanks again, I compare how much I actually burned to what the totalizer says and adjust the K factor accordingly. (I can completely empty the wings on my plane because my engine runs off a header tank.)
If you can't empty the wings in flight and if you have a scale, you can weigh the gas you drain out of the wings.
