Looking at this part of the plans, and trying a measuring tape at first, I found it difficult to get consistent measurements solo.
So I came up with what may or may not be a unique solution. I took a piece of wire and crimped a ring connector on it, then secured it to the center forward rivet hole and measured the distance and made adjustments. I was careful to twist the connector to point in the correct direction.
Connector/wire:
Using small piece of tape to mark exact position at each corner:
Connector/wire:
