Our elevator trim servo indicator is on a Skyview screen. When we set the trim to neutral ( flush with the elevator on both sides) it reads up higher (about at the 3/4 position of the full scale) rather than the center. The indicator also tops out before the trim reaches the all up position, ie the scale stops moving before the trim stops. The Skyview has the capability to show movement in volt readings , from 0 to 5 volts . When the graph stops climbing the voltage is at 5 volts, and does not change with the traveling servo while it is finishing it's stroke.
This leads me to believe the potentiameter( spelling?) is out of sink.
Anyone have a problem with a Ray Allen servo like this?
Ron
Ron
