Hello All,
I have two 10" Skyview Displays and a VP-X. The VP-X manual shows to wire the serial port to both displays. Each display has a provided wiring harness and the serial lines are all non-shielded twisted pairs. I have already found comments from Dynon that they feel the serial lines do not need shielding even though the VP-X manual shows shielded. I Agree with Dynon and will not use shielding, but my question is going from one VP-X wire to each wire on the Dynons. One wire to two wires.
Can I use a crimp style splice here, or should I solder? I have a high end crimper that does a good job but would seek wisdom from the crowd that knows.
Thanks for the anticipated input.
