I'm trying to figure out how best to connect the serial ports on my 'stuff'. The GTX327 and GNS430W installation manuals say the GTX327 should be connected to RS232-1 on the GNS430W with TX and RX ports configured for Icarus-Alt, the AF3500EF manual says the the same but the ports configured for Aviation, and the TT ADIpilot II says it only needs the Tx port on, you guessed it, RS232-1 on the 430W but also configured for Aviation. ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Does anyone know if the four serial/RS-232 ports on the Garmin GNS430W are the same? If so I could connect the AF3500EF to RS232-1 (Aviation), the GTX327 to RS232-2 (Icarus-Alt) and the TTADIP II to RS232-3 (Aviation). Thoughts/Suggestions?
