Hi.
I'm in the process of doing the last zilloin tasks now, and one of them was connecting the wires in the wingroot.
When connecting the wires from the Vans fuel level senders, I noticed that the senders had no grounding wire.
(The kit is bought partly done)
I easily installed a separate gound wire for the sender in wing with the conventional fuelpick up, but the sender in wing with the floptube is not accessible without removing the tank.
I know that the instructions doesn't mention a separate ground wire, but I think it's a good idea anyway?
My question is this: is it really necessary to install separate ground wires for the Vans fuel level senders?
Or is it ok to install the + wires and let the grounding be taken care of by the tanks itself?
Maybe I'm overthinking this, but it's always nice to hear from other builders....
