sensenich prop spacer
danweseman
Active Member
Im working on a rv-4 with a sensenich metal prop . It has 2, 2 inch thick aluminum spacers between the prop and crank flange. They say spm8s8 on them. has anyone seen this "stacked spacer" setup before. Thanks for any info Dan Weseman
Re 2, 2" prop spacers
I have not, however if decide to go with a 4" spacer I have one for an O-320 I will trade you. I need the 2"...
