edward7048
what has been found to be the best self etching primer to use on the
inside of an aircraft?
I used Rustoleum self-etching aluminum primer from Ace Hardware, although probably at your local box store as well. About $4-5 a can and works very well with a good base for their satin gray finish as well.
The 360? spray nozzles work very well and worth the "big bucks" cost.
Try a test. SEM, Nappa, Rustoleum. My bet is the SEM will adhere
The best. It's more expensive but Very good. I used it on my interior and
Have had no issues with adherence.
