Almost done with section 28. The landing gear mounts are painful to work with. A quick search through VAF finds that its not uncommon. A little (or a lot) of incentive with a mallet lined up the holes so I could put the bolts in. They're in tight for sure.
Then it has you put the shim in between 1004K and the mount. The shim is even tighter. Had to use a hammer and something to push it between the 1004K and mount. Is this normal? I don't want to match-drill (step 2) if its not. Most everything else lines up well, so this was odd.
![F736F5C9-D114-4965-B0A8-D40E966B6EF9_zpstlfryjqe.jpg](/proxy.php?image=http%3A%2F%2Fi377.photobucket.com%2Falbums%2Foo217%2Fscorwin75%2F2015-10%2FF736F5C9-D114-4965-B0A8-D40E966B6EF9_zpstlfryjqe.jpg&hash=1c1055d899ffc18313f62223e7415710)
