I'm not sure of the exact page number as I don't have the plans with me, but I'm hoping to get an answer before I head back to the shop tonight...
I'm at the point where I'm attaching the left and right seat assemblies to the main bulkhead assembly (the sub-assembly with the big aluminum U-channel that came mostly pre-assembled).
Clearly, the rivets on the top flange are attached with the manufactured heads on the seat side. What about the rivets that attach the seat rib flanges to the bulkhead?
Usually, I would put those heads on the flange side because it's the thinner material, but I recall that when attaching the baggage compartment assembly, the instructions specifically said to put the manufactured heads on the bulkhead side.
So, which way are you guys doing it? Does it matter? Thanks.
