Section 21 Page 16 Unfilled holes?
gblwy
Patron
Hi,
Does anyone with a completed aircraft have any unfilled holes in the bottom skin of the fuselage?
I have two holes. The first is 1/8 inch, just forward of the access hole for the flaperon bolt. Inside the square of rivets holding the brackets for same.
The second is a slightly larger hole on the centreline just behind the rearmost pair of screws holding the system blocks.
Neither hole appears on the plan.
Thanks...Keith
Having just riveted the "extra" 1/8" hole by the hole in the bottom skin (i.e. F-1276) accessing the head of the flaperon mixer bolt, what is the purpose of this hole?
Namely, do I drill it out or leave it in?
Thanks.
Brett
Columbus, IN
I don't have my plans in front of me at the moment. However, there are a number of larger holes located throughout the RV-12 that were used for initial machining/CNC alignment and serve no purpose during construction. I like to think of them as drain holes. 😉
