JerryG150
The note on pg 10-08 states to leave the ties on the 1208 frame and forward of the 1208 frame loose. But after I riveted the 2 ports and threaded the tubing thru the 1208 frame and attached to the 2nd. port and forward thru the j stiffeners as per instructions with the p30 wire also in place can I THEN tighten all the ties on the 1208 frame and forward? Once I add the tailcone skin it will be much harder to get to.
