The D180 installation manual tells you to ground the shield from the OAT at the magnetometer ONLY if interference is experienced. I soldered a short piece of white wire to the shield, bent it backwards, passed it thru the heat shrink and let it extend just an inch beyond the end of the heat shrink. I'll be able to crimp a barrel connector on it, IF it is needed
