lluciani
Active Member
Has anyone installed a second seat belt for the pilot in an RV8? It seems to be highly recommended and even required in some cases for aerobatic competition. I suppose the requirement can be met using the same attach points as the regular seat belts but redundancy would suffer.
If someone has done this, where is the best place to install them? I presume to the two longitudinal ribs under the seat but these seem too close together. Thanks in advance.
Luis Luciani
RV8, 100+ hours
Luis Luciani
RV8, 100+ hours
