woodsideraff
I'm adding an SL40 for a back-up to my 430W.
My transponder antenna is located on the centerline, just behind the spar. The 430 comm antenna (whip) is also on the centerline, about 2 ft back (where the rear control stick is).
I'm planning to place the second comm antenna further back, on the centerline just behind the main baggage floor. Anyone see a problem with this setup? It would be nice to know before cutting a hole in the belly and having to patch it up later.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks and best regards,
Rafael
Rafael
