I can't get beyond neutral on forward throw of the stick. The 610 hits the seat ribs. Unfortunately I didn't figure out where the hang up was until the powder coat had been gouged. Anyone had this problem or know a fix?
I don't think the ribs are cut exactly like described in drawing 22. Close, but just far enough off to give the interference. As you already determined, make clearance cuts and move ahead.
Had the same problem on my -9A. Solution was to get the angle grinder out and let 'er rip! Well, not quite, but a bit of filing was enough to eliminate the interference.
Here is the best shot I have of the offending area on my 9A, you can see a couple of the ribs with some material removed. You don't have to take much, but you do have to take some.
