Vans will sell the foam if you want to take them to your local upholstery shop or cover them yourself, but they're are aftermarket sources that will hook you up as well. Classic aero is popular, as is Lemke interiors out of Germany.
Vans sells the foam seat blanks if you want to do your own covering like I did. I've seen simple chairs cushion used bit they won't score very high at oshkosh
I'm using foam that I bought locally. The store has various thicknesses and densities and I experimented with different layers to get the right seating position and comfort. The cushions are just flat and aren't flashy looking like in a Cirrus.
