In the near future, I will be installing my RV-12's rear window. Has anyone seen the need for and/or used some form of protective/cushioning material (e.g., plastic tape, window sealing tape, etc.) between the Lexan and the roll bar? Such a seal might improve the appearance of the installation (i.e., no rivets showing and no crud build-up between the sandwiched Lexan/roll bar) and might provide a better seal against wind noise and rain entry.
Any thoughts as to a good material for this?
Thanks -- David
Thanks -- David
