acam37
I need to know what is the best way to seal an exhaust pipe slip joint connection? I have a standard exhaust system for the 0-320 that has slip joint connections where they cross over under the engine. The problem is that unburnt smoke oil is is blowing out of the joint and covering the engine causing a big mess and potential fire hazard. I thought of just welding it up, but not sure if the slip joint is there for a reason, such as allowing flex in the exhaust system.
