Fellow 10 builders using SDSFI,
Where did you or plan to firewall mount the fuel return pressure regulator and return firewall bulkhead fitting?
I have seen some of the EFII regulator mounts but these are somewhat different considering that the EFII fuel loop is lower on the engine around the bottom of the cylinders. I am using top cylinder mounted injectors so the fuel feed and return lines interface on top of the engine....similar to a mechanical injection spider/purge valve assembly.
Considering future access to engine items like oil filter, aux alternator, ignition coil areas and keeping the regulator from seeing excessive radiant exhaust heat is a balancing act. Any pics would be greatly appreciated before I bust out the drill and get myself into trouble.
Thanks!
Thanks!
