I am having some issues with getting my throttle cable/throttle body arm adjusted correctly. The arm is a little shorter and the throttle body is farther aft than the air flow system it was designed for. When I pull the throttle to idle, The end of the throttle cable contacts the throttle/mixture bracket before the throttle arm can get fully closed. It is also rubbing the lower forward case bolt the front of the throttle/mixture bracket is attached to. I realize there are SDS EFII 14A builders that are flying that have run across this issue. Trying to figure out the simplest way to remedy this problem.
If you have and SDS system on your 14 or 14A could you please PM me or post and let me know how you solved this. Also, pictures would be a great help as well.
Best,
Jim
Best,
Jim
