As most of you have probably figured out now, SDS is no longer associated with EFII as of early Sept. of this year.
We've had quite a number of EFII customers come to us for tech help and ask about software updates/ upgrades. As per our standard policy, we help anyone with SDS manufactured products, no matter which dealer they were originally purchased from. Be aware that we can really only support/ repair/ upgrade the ECUs, programmers and Hall sensors as these were the only parts we supplied to EFII before. EFII did their own things with wiring, sensors and other externals which we have little knowledge about.
If you're interested in EM-5 ECU software upgrades or optional features not offered by EFII- PC data logging, individual cylinder fuel trim, direct fuel flow output etc., we can reflash ECUs and sell you these options plus offer the tech support for rewiring if required.
There are also hardware upgrades available like the variable brightness displays, head mounted injectors, barometric compensation etc. we can help you with.
Anyway, I just wanted to tell people they don't own an orphaned system, it's still supported by the factory and will continue to be in the future as we continue to work on new features, hardware and software.
We can help you immediately with your needs.
