FlyBoy8
Active Member
The scratches around the rivet holes in this VS skin occured when I was trial fitting the skin to the structure. I guess I wasn't being gentle enough. I'm a little paranoid about scratches after reading in the manual that all scratches should be removed etc. I would appreciate comments from experienced builders on the best way to handle this. Thanks in advance.
