There is no reason to have the wire so long that it has to slip over the flange. That just makes it impossible to get it over the flange. Trim the wire back inside the tube about 3/4 of an inch and bend the tip of the wire so it doesn't poke through the outside of the tube.
Then the tube slides on the flange easily. Secure with a clamp and you are done!
Gary Specketer
