Our original plan was to split the two heat valves up. I was going to split the right valve and supply both the front and rear with heat using just that side. I was going to use the left valve for cold air and install eyeball vents in the sides of the tunnel to provide cool air to the foot well area.
I spoke with Vetterman, who suggested that if I remove the left heat muff I should install a heat shield on the top side of the muffler to deflect the heat down and out the back of the cowl.
I changed my mind and just hooked it up per the plans and used stainless heat valves with insulation between them and the firewall. I have layered 1/4" fibrefrax, covered by 1/2" fireproof insulation on the entire floor, including the tunnel floor and the entire firewall. My plan is to see how it does. If the tunnel is too warm I will then make the mod that I was originally going to incorporate.
After reading all of the posts on the tunnel heat issue, it seems that most of the issues are resolved by the newer extended exhaust system, adding floor insulation, and the use of the stainless valves.
The only other thing that would improve the overall heat dispersion would be if the heat valves had a scat tube outlet so you could dump the heat at the exit at the bottom of the firewall rather than so far up on the firewall.
