Hi
The SB calls for the aft hole in the outboard HS rib to be enlarged to allow inspection with a scope.
This can't be done as the elevator is in the way when in full up or down position.
The SB does not say it needs to be removed first. Must it be removed or can I make a new hole further forward?
