So i finally figured it was time to complete this SB and I'm just waiting for the parts to be returned. While waiting I thought I would start researching what i had to do after the parts arrive. Unfortunately, I can't seem to find much about how to complete this.
I did a pretty extensive search here for a step by step instructions or even where someone else had completed the install and gave advice. Most of what i found was about re-threading the leg yourself and changing the wheel pant to the new type.
I also checked Vans site but I can't find any drawings or installation instructions. I'd thought there would be drawings like the original build instructions. I was going to call them one of these morning to find out if any instructions will come with the new parts.
For instance, i've ordered a stop flange as per the SB. Where does it go? What type of solution (grease?) do i put on the two matting surfaces between the gear leg and the engine mount? Will i be torquing the fork nut the same as the original instructions?
So if anyone has a link to someone else that has done this please pass it on. I don't know how many others will be getting ready to do this SB but i will post what happens and how I complete it
Thanks in advance
Thanks in advance
