SB-00036 Non Pre-punch Help Needed
DickF
Active Member
I managed to mess up the match drill process and I now need 2 Hinge Brackets part HS-00717B. These are the hinge brackets from the repair kit RV 6 Non-Prepunch HS-603.
I’ve ordered a new kit, but it is on backorder until the end of May. I’m hoping someone might have 2 brackets that I can borrow and then replace when I receive my backorder.
Will you guys post your experiences with the match drilling process so that we might learn from your mistakes?
Thanks a ton!
