A few weeks back I brought home a Craftsman 10" bandsaw after reading relatively good reviews of price vs performance. I've got to say that other than separating parts or doing light trimming the saw is not that good - not the cleanest cuts and it bogs down easily. I put a 14tpi blade on for metal, and used the included blade trying to cut 3/4 inch oak for the trim tab blocks and that took a very long time.
On the other hand, I put a 96 tooth non-ferrous capable blade on the 12" sliding compound miter and that thing cuts great, it's just that it's only good for bigger or longer stuff - too hard to try to come up with a method to hold down smaller pieces near the blade. I'm pretty sure i read that recommendation here, so thanks for that. As part of my continuing education I also learned that a hinge pin should not be considered non-ferrous metal...and will probably replace the blade with one that still has all of its teeth.
Lastly, I was getting ready to put the top skins on the tail cone when I realized I had cut my last j-channel too short - I read 60 instead of 68 inches. Being conscientious, I ordered a replacement and waited to continue til it arrived. After measuring twice and marking once, I managed to destroy that channel (or at least make it not usable for a 68" reach). So now I think I'm going to do what I could have done last week, overlap two pieces of j-channel to reach the distance with enough overlap to get 6-8 rivets in both. I'm thinking it's just a stiffener, so why not?
==dave==
41373
Wing Kit ordered
==dave==
41373
Wing Kit ordered
