Ditto,
you can mix a batch at one time then pop the batch into the freezer, and use as you go. Just don't let is sit there to long, it will go hard eventually.
On my RV7 tanks I mixed a big batch enough for a couple of hours of work, and just use as I need. It was easier to run to the freezer than mix and clean up each small batch.
PS: old spool film canisters work great for storing work sized amounts in the freezer for the day.
