N9331v
Im going to order my finish kit Monday and still learning as I go. That being said I'd like to ask the -7 guys that went with the Sam James cowl the following
Did you do make any deletions from the Vans finish kit besides the cowl ?
If I go with extended Sam James cowl can I still use a constant speed prop since the prop needs a extension ?
If I go with this cowl is the plenum a must have item ?
Anything I may be missing ?
