The manual is not in front of me but I dont remember seeing anything about installing safety wire on the prop bolts of the 200 RV prop. This prop uses large castle nuts on studs, and the studs have semi-permanant pins through them that engage the lugs on the castle nuts. So, when you tighten the nuts, you are actually tightening the studs. The pins are hollow, so its possible to thread safety wire through them, but the wire will contact part of the hub between any two adjacent castle nuts, so safety wire really doesnt seem feasible to me. Is my thinking on this correct or am I missing something?
thanks
erich
thanks
erich
