I would like to put the OAT on the underside of the fuselage just behind the bulkhead at the rear of the baggage area. This would put it about 7' behind the firewall.
Is this going to be okay ?
Mark S.
Nothing in potential heat flow is going to be accurate. Lot put out on underside of wing. Mine is pretty accurate +/-3 and mine is in pilot side fresh air naca duct. The error is heat from cowl, being it is so close. Just one opinion, others coming.
