I fly a PA18-150 Supercub and am building a 9. Comparing specifications and performance between the two is very interesting. To make the numbers more accurate, I'd like to know if anyone has performance results using 150 hp engine on the RV9? Here's what I have from the PA18 POH and Van's numbers for the RV9-160.
Specifications PA18-150 verses RV-9
Span 35' 3" / 28' 0"
Length 22' 7" / 20' 5"
Height 6' 8" / 5' 10"
Wing Area 178 / 124
Empty Weight 930 / 1043
Gross Weight 1750 / 1750
Wing Loading 10.00 / 14.1
Power Loading 11.7 / 11.7
Engine 150 / 160
Prop Type Fixed / Fixed
Fuel Capacity 36 / 36
Baggage 50 / 100
Performance PA18-150 vs RV-9 (RV numbers w/ 160 hp)
Top Speed 130 / 196
Cruise at 75% hp 115 / 188
Stall Speed 43 / 45
Take-Off Dist @ Gross 200 / 400
Landing Dist @ Gross 350 / 450
Rate of Climb at Gross 960 / 1750
Ceiling at Gross 19000 / 18500
Range at 75% hp 460 / 740![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Wing Area 178 / 124
Engine 150 / 160
Baggage 50 / 100
Top Speed 130 / 196
Stall Speed 43 / 45
