Raja, here are the control surface deflections, from the Vans manual:
As you can see, you're short on down elevator travel (14 measured vs 20 minimum), although middle of the acceptable range in up elevator travel. Obviously the ability to raise the nose to stall attitude is not a function of down elevator, but the rigging does suggest things are not quite right. Let's check two details.
First, elevator stop contact points. The elevator arms should contact the points detailed below with a nice firm clunk, before any kind of resistance or binding can be detected in any other part of the elevator control system. That includes stick contact with seat backs and cushions. The deflections should be within range with the arms in firm contact as described. If necessary, these fuselage stops are filed as needed to allow appropriate elevator travel.
Second, an assembly check. It's possible for a builder to miss an important note on the assembly drawing. Inspect around the bottom flange of the horizontal stabilizer rear spar. There should be a 3/16" space between the aft deck plate and the underside of the spar. If the rear spar was drilled to the vertical attach bars without a 3/16" spacer to set the gap (drill bits are common), the HS incidence is wrong.
