RV8, IO390, Showplanes cowl
JDA_BTR
So this is my combination. It was my understanding that with an IO360 the showplaces cowl needed a 2" extension on the prop flange. Is this the same with the IO390? If such is still needed, where is the extension gotten from?
Also, there isn't a firewall forward kit for the 390 on the RV8. Any suggestions?
Thanks for that I def needed the link. I'm hoping someone chimes in to answer the other questions....
It might depend more on the prop than the engine or cowling. I know most Hartzells require an extension, but my Whirl Wind 200RV prop did not need one for my IO360.
A metal Hartzell on a shaft extension with a 390 is going to be heavy in pitch when solo....like two hands for a loop entry. Tough on motor mount rubber too.
Mine is quite heavy without the shaft extension.
Modified Vans cowl, standard length.
