I would delete the undercarriage and get a gun drilled aluminium set from Grove. Lighter and an easier install with no brake lines down the leg.
https://www.groveaircraft.com/gundrill.html
Also get their radius plates as well which support the legs.
Yes they are not produced anymore but you could get nearly the identical ones from here:
https://www.skydesigns.aero/rv-8-alum-airfoil-landing-gear
Thanks, Gary, for your kind words but I have to clarify that it is actually Susan who is great to deal with...I'm the engineer and everyone knows how difficult dealing with engineers can be!
The Sky Designs legs are, IMHO, a bit prettier than what Grove used to offer...here's a photo of a set I just polished and the reflection nicely shows-off the shapely design.View attachment 11990
Look into the tailwheel assembly as well. Flyboys Accessories has some very nice options for the tailwheel. If you do delete the Van's tailwheel assembly, don't forget to re-add the tail spring mount and the tail spring. (not that I learned the hard way or anything)
I agree!That is where I purchased mine. Ken and Susan are great people to deal with.
