I suppose I would if I could use it on my IPad. I wouldn't be able to haul a PC around for weight and balance calculations. I will check also Foreflight. PM me on the details when it's convenient.
Setup wt and balance in my Foreflight app. The result was a square box with the forward cg on one vertical axis and the aft cg on the other axis. The bottom horizontal axis was the empty weight (1167#) and the top of the box was 1800#. So I assume that it's not possible to get out of cg without exceeding max GW of 1800#. The baggage limit I entered was 100#. Does anyone else's Foreflight WB envelope look like a square box?
