There are different bolts in different locations... You'll have to specify which bolt.
If you look on the plans I believe it does specify the recommended bolt for each position.
When I attached the wings on my -6A sixteen years ago, I made a scale drawing to help me get the right bolts in the right locations with all the required brackets and flanged parts as well as the 4 steel spar splice plates installed. I pulled the information from 2 or 3 different construction drawing sheets. It would have been nice if all the attach hardware was in one location, but that was not the case.
There are a total of 76 bolts that hold all this stuff together. So here is what my sketch shows:
Plus the washers and nuts.
NAS 1306-30
NAS 1304-30
AN3-15A
AN3-16A
AN3-17A
AN4-16A
Thanks for the info. The bots that go through the steel splice plates are the ones I?m interested in. What is the AN number for those bolts. Thanks again for the great response!
Thanks very much for the info!! I don’t have sheet 15. Would it be possible to take a photo of the NAS bolt call out section and email to [email protected]. Thanks!
