Need to repair the outboard leading edge. There is a possibility of a proper patch but overall it would be best cosmetically to replace the complete panel. Has anyone done same? Not sure when Van's changed over to pre punched panels (this is an older aircraft), so having the holes match might be an issue. The shaping of the 2024T3 .025 around the leading edge, would anyone have suggestions starting with 4' x 5' sheet? Thank you...
