I am looking for some advice on removing the rear wing spars from a completed pair of rv6 wings. I need to replace the two inner pieces (W-607D and W-407) on both wings spars because they were drilled incorrectly by the previous owner setting the wing incidencd. It appears that they were not satisfied with the wing incidence so the drilled a second hole on each seide to correct the wing incidence and the two holes overlap creating a long ?figure 8? looking hole. I was informed that this bad hole makes it not airworthy. Any advice would be greatly appreciated.
Scott Louis
RV 6 in progress.
Scottelouis at gmail
Scott Louis
RV 6 in progress.
