Hey guys I am in the middle of design for my cockpit/interior...and am asking if some of you can send me pics of your interiors to give some ideas of what i would like to do....appreciate the help...thx,todd
Suggest map pocket, the straps with snaps great for getting the headsets up and out of the way, you can see headset jacks front and back-they worked out well, the center panel below inst panel should not be is a good place for overflow if you run out of panel space, NACA scoops in right side of canopy are give marginal air - added VG's and got OK air out of them after that, the OAT in the NACA airscoop is a bad place for probev- must be away from the engine heat either outboard (in wing) or aft (tail area).
