Scott Hersha
I modified my front stick in my RV4 to accommodate my seating position. I have moved my front seatback aft 2.75” at the top (rollbar, etc.), and 1.75” at the bottom (hinge) because it just felt like I was too close to the instrument panel. I’m 6’2” and weigh 200 lbs, and need more room than the stock RV4 affords. My skinny, light weight wife doesn’t like the back seat of a tandem airplane. My grandkids do, however, and there is plenty of room left for them........ anyway, the reason for my post...... I’m back a ways from the stock stick location, and with an extra 1” of tilt backwards, I was leaning over a bit to comfortably reach the stick. So I decided to install a bent stick that would place it where it was comfortable for me. I’ve done this on both RV8’s that I’ve owned, but on those I cut and welded the stick to create an offset. On this RV4, I used an RV14 stick, and modified my existing stick to attach it. The RV14 bent stick ($26 from Vans) is 7/8” diameter, and the RV4/8 stick is 1”. The smaller one doesn’t fit snugly into the other, so my friend Bruce Brielmaier milled a length of 4130 cromolly to fit into the RV4 stick, and over the RV14 stick. I used some Locktite 668 (bearing mount stick) to help hold everything together, although it fit so tight I don’t think it is needed. This stuff is supposed to be used on cylindrical metal assemblies and if used doesn’t require the use of standard clamps, snap rings, etc. I still used 2 AN3 bolts, as is done on the RV14. I flew this new stick today, and have to say, I really like it. The stick is in a more comfortable, natural place for me, and makes my sport plane feel more ‘sporty’. I made it about 3/4” taller than original. I did an entire acro sequence and didn’t have any trouble with control limit clearance. The RV4 front stick is the same as the RV8 stick, so it would work there also. The upper portion of the bent stick is tilted slightly forward (see pics), so in the full nose up stick position your hand/wrist isn’t tilted at an uncomfortable angle.
I posted these pics from a google drive app, so I don’t know if it will work.
https://photos.app.goo.gl/NYaQ3sE730f1LPPG3
Updated post...
Updated post...
