RV14 Throttle/mix/prop
rjm727
Has anyone repositioned their RV14 throttle/mix/prop to either a center pedestal or sidewall application (like an RV 8)? If so, pics and any early considerations you recommend would be great.
Looks cool, I'm sure removing the floor pans/center panels/fuel filter will be a joy come inspection time :eek:
All these great mods make maintenance much more difficult, which often translates to it never gets looked at.
It's not bad enough you have to take out the CB panel to access the fuel pump/filter, but now you have to remove entire center console/control quadrant too.
Unless they went with wing root filters or the external access gascolator? (Either of which is probably mandatory if you went this way). Does the fuel pump need inspection at the annual or just the filter?
