RV12IS /Rotax 912IS engines
TS Flightlines
Advertiser
For you RV12IS owners, do you see any differences in the fuel flow readings with with the higher pressures of the Rotax pumps? Mainly looking for the STABILITY of the readings, and not necesarily the actual flow reading itself.
Doing some 'cyphering'
Tom
Sometimes when I'm just cruising around I set the throttle to achieve a specific fuel flow, and it pretty much just stays there. Remarkably stable.
