I have an RV12 and am having trouble completely draining water from the fuel when it has intruded into the tank.
I don't seem to be able to drain all the water in one glug as I'm used to when draining directly from the tank in other aircraft. Instead, fuel with a very small amount of water in it comes out continually as I drain. I can sample a gallon or more of fuel before water seems to be depleted. The total amount of water drained may just be a couple of tablespoons.
When draining I turn the fuel pump on, let it run 30 seconds or so, then drain from the gascolator. No water accumulates in the gascolator before sampling. Instead, water only seems to flow when fuel flow increases while sampling actually takes place.
My father, a retired airline A&P, suspects surface tension causes water to stick to the screen at the fuel line in the tank. His theory is that the increased pressure caused by higher fuel flow when sampling is enough to overcome the surface tension and pull water through this screen.
Any thoughts? Has anyone experienced or dealt with an issue like this in the past? Many thanks in advance!
As an aside, the plane lives outside. I suspect water gets into the fuel tank around a loose seal between the gas cap and filler neck and have replacement parts on order to rectify this.
