I have a 2017 model Experimental Amateur Built RV12 with the Rotax 912ULS engine. It currently has about 370 hrs on it.
It has the 2 blade composite Sensinich prop. I purchased this aircraft back in February 2024 and did a pre-buy and condition inspection. The logbook entry for the condition inspection says a carb balance, carb inspection and cleaning ,engine gearbox friction checked currently at 470 inch pounds.
When I am in cruise flight and enter the pattern to slow it down and pull the power back I get a noticeable vibration at around 4000 rpm and below.
Can anyone suggest where to start looking?
Thank you,
David Heiman
N463CS
Thank you,
David Heiman
N463CS
