udayaggarwal
I'm New Here
When using either MOgas (91 Octane) non ethanol or AVGas interchangeably on the RV 12 Rotax 100HP engine, can I mix the two if I've filled MOgas initially and then topped off with AVGas? Is an additive required? This is my first airplane and I've no idea whether I should be mixing the 2 and or using any sort of additive as preventative measures.
Any insights into this with directions for use would be very helpful.
