I am probably 6-12 months away from finishing the fuselage kit and starting to planning finances and timing for finish kit and engine. I am not yet certain where I will order the engine from so not sure of the lead time for that item.
Questions
1) How much work is there to done (hours) on the finish kit that does not require engine to be hung?
2) I am building in my basement so I want to keep if off the gear as long as possible as it will not fit out my basement with the gear on. Is it possible advisable to mount the engine without the gear in place? (Keep it on a cradle with engine?)
Steve
Questions
Steve
